Engine Mechanical problem
1990 Buick Regal 6 cyl Front Wheel Drive Automatic
My water pump went out and now when I fill my raditor water ends up in my oil pan
Sunday, February 1st, 2009 AT 3:24 PM
JDL
MECHANIC
Did the engine overheat after the pump went out? If nothing cracked or warped, maybe it's a gasket.
Tuesday, February 3rd, 2009 AT 7:21 AM
JUSTIN3146
MEMBER
I put block sealer and gasket repair in my car and now it won't start. I t is like it is not getting spark. I checked the plus and they are fine. I changed the wires and it started for about five minutes then died now it won't statr again
Tuesday, February 3rd, 2009 AT 6:24 PM
JDL
MECHANIC
Are the cranking rpms ok? Does it crank good? Have a helper crank it, while you check for spark at the plugs. If you have good spark everywhere, check fuel pressure.
Are there any trouble-codes? If the vehicle overheated you may need to check cylinder compression. Is there any cranking vacuum?
