1989 Buick Regal Hard Start
DANIEL2283
  • 1989 BUICK REGAL
  • 6 CYL
  • 187,000 MILES
I just bought a 89 buick regal 3.1L! When I bought the car it did not run. I replaced the bat, fuel pump, and did a tune up on it! It runs but it is hard to start once started runes fine. What would be the cause of this hard start problem? I know on the 91 I would tap the ign and it would fire right up and the 89 should do the same!
Monday, October 26th, 2009 AT 7:29 PM
  • 109,885 POSTS
Have you checked fuel pump pressure?
Friday, October 30th, 2009 AT 1:39 PM
DANIEL2283
Yes, pump pressure is good!
Friday, October 30th, 2009 AT 7:28 PM
  • 109,885 POSTS
When you checked the fuel pump pressure, did you pay attention to fuel pressure drop off? I'm thinking pressure isn't being held in the system due to a leak or bad fuel injector. As a result, the system needs to rebuild before it will start.
Friday, October 30th, 2009 AT 9:37 PM
