I replace the Alternator on this car 1 month ago. Eveything work fine until last week. It began giving symptom like the alternator is bad again... ticking sound when I tried to start the car. The car starts with not problem while getting a jump from another vehicle. However when I try to drive any distance it cuts off as if the battery is not staying charge. when I get a jump..it stats and run great for a while but again it seem the battery is not staying charge. Today I had the battery checked/charge and installed a new alternator. The car started and ran good. I cut it off for about an hour..went out and attempted to start it up...same problem. What else can this be? More info about the model of this vehicle..its a 3.8 liter Turbo fuel injected G/N
Mar 30, 2009 at 12:52 PM
