1978 Buick Regal Car keeps stallilng at idle
49,000 MILES • 6 CYL • 2WD • AUTOMATIC
FIRE1181
Changed fuel filter out on front of carb, now the engine will not idle. Only can keep car running while keeping foot on gas pedal. It is a 3.8 turbo. The new fuel filter is sealed on one end and has a rubber gasket on the other, which way does the gasket go. Also is there any springs needed and is there a special tightness for the fuel filter housing.
Aug 23, 2010 at 2:59 AM
  • 110,248 POSTS
There are no springs. As far as the filter, the gasket points out. When the car stalls, can you smell raw fuel? Also, was there any trouble prior to replacement?
Sep 4, 2010 at 2:32 PM
FIRE1181
Yes there is a raw gas smell now since gas filter was changed out properly. Adjusted carburator so stalling does not occur. But cannot get rid of the raw gas smell now.
Sep 5, 2010 at 3:54 AM
  • 110,248 POSTS
There has to be a leak somewhere. If the engine is running properly now, check connections, hoses, and steel lines for leaks.
Let me know what you find.
Sep 5, 2010 at 5:27 PM
