1992 Buick Park Avenue Idle Knock
CUTEHELLRAISER
i have a 92 park avenue its got approx 350,000 kms on it. i recently hit the dicth with the car. a few days after hitting the ditch , the motor started a really loud knocking noise. it only knocks when its idling and stops when u rev up. What could be wrong?
Mar 21, 2007 at 6:03 AM
BOOTDOG
  • 665 POSTS
before assuming it's an internal engine knock, check all the pulleys for play, (including the water pump). a bad bearing , (i.e. water pump), can make a knocking noise which the sound will amplify through the engine.
Mar 21, 2007 at 9:45 AM
Suggested Repair
Before assuming an internal engine knock, check all accessory pulleys for play, including the water pump. A failing bearing can sound like a knock that is louder at idle and quiets when the engine is revved.
Conversation Summary
The owner of a 1992 Buick Park Avenue with about 350,000 km reported a loud knocking noise that started a few days after hitting a ditch. The noise occurs only at idle and stops when the engine is revved. The expert advised checking all pulleys for play, including the water pump, because a bad bearing can produce a knock that is amplified through the engine.
