1996 Buick Park Avenue Shakes Accelerating
BLACK_STANG_02
Hey everybody, I have a 1996 buick park avenue ultra with a v6 3.8 supercharger engine that has about 217000 mile on it. My problem is, when I accelerate from a stop the car will vibrate. It also vibrates will I accelerate harder in any gear while driving. But stops and runs fine after I release the pedal. It does not shake in reverse. only in drive. It feels to be comeing from the passenger side front end. I tried to find the problem by putting the car in drive and had someone hold the brake and give it some gas, it did vibrate,but I could not pin point the vibration. Ive changed, the oil, spark plugs, wires, fuel pump, fuel filter, all three coil packs, and the air filter. the car runs great. accelerates fine, doesnt wast much fuel, it just vibrates alot under acceleration. If i let off the gas pedal it stops. What could it be?
Aug 28, 2007 at 6:49 AM
82STANG
  • 15 POSTS
Maybe engine mount
Wheel bearing
Oct 19, 2007 at 4:50 PM
NDDUNC
  • 47 POSTS
sounds like the spacer in the supercharger is going out! please email me at nddunc@yahoo.com... if interested!
Dec 30, 2007 at 5:48 AM
Suggested Repair
Have the supercharger spacer inspected and replaced if it is failing. Engine mounts and the wheel bearing were also suggested as possible sources of the acceleration vibration.
Conversation Summary
A 1996 Buick Park Avenue Ultra with a supercharged 3.8L V6 vibrates or rattles under acceleration in Drive, including from a stop, and the vibration stops when the accelerator is released. It does not shake in Reverse and seems to come from the passenger-side front. Routine maintenance and ignition, fuel, and air-filter parts have already been replaced without curing it. Replies suggest an engine mount or wheel bearing, while the expert attributes the problem to a failing supercharger spacer.
