1999 Buick Park Avenue Headlight High Beam switch does not
99,812 MILES • 6 CYL • FWD • AUTOMATIC
TOMPARKER
My car is equipped with daylight running lights which work correctly, as do the low beams. I am able to "flash" my high beams but the high beam switch does not work. Could it be either a relay or the switch? How do I get to it to fix it?
Sep 22, 2008 at 12:10 PM
2CARPRO JACK
  • 11,533 POSTS
If you pull back on the lever they will flash, but if you push forward it wont stay in that position or they just dont come on? It could be a bad switch. You have to remove the steering wheel to access the "multi-function" switch
Sep 23, 2008 at 1:00 AM
