1999 Buick Park Avenue engine oil leak
1999 BUICK PARK AVENUE
69,000 MILES • 6 CYL • 2WD • AUTOMATIC
BCREVASSE
This car has leaked oil after 25k miles. GM replaced the valve cover still leaked . GM replaced the intake manifold gasket at 60k still leaks.
What your best bet on source?
Aug 8, 2009 at 5:27 AM
THIS IS MIKE
  • 686 POSTS
It can be leaking from the valve cover gaskets, the rear main seal, or the oil pump. You can take a flash light and look for the source.
You can take it to a different mechanic and have them inspect your engine for the source of the leak. They can also check the quality of the previous repairs and give you an estimate for the repairs.
Aug 17, 2009 at 6:34 AM
