Car shuts down while driving
GHOSTRIDERJOE
  • 1999 BUICK PARK AVENUE
  • 6 CYL
  • FWD
  • 113,782 MILES
I have a 1999 park avenue.
When it gets up to operating temp. The car will shut off. It will start when cold and run fine until it gets up to operating temp, I have put in a new fuel pump replaced all the plugs, and the fuel pressure regulator,
Cleaned the idle air control valve, it is moving fine and is set to 11/2 inches, when you try to start it will hit and die right after it hits, no lights or on.
Sunday, January 5th, 2020 AT 2:01 PM (Merged)
I suggest you check the fuel pressure if its within specs
Sunday, January 5th, 2020 AT 2:02 PM (Merged)
GHOSTRIDERJOE
Fulr press. Is goden
2CP-ARCHIVES
  • 4,540 POSTS
  • 77,700 MILES
Car dieing off and sputtering. I recently put fuel injector cleaner and premium fuel in car but it continues to sputter and die off.
  • 52,797 POSTS
Fuel injector cleaner additives rearely work.
Have the fuel pressure checked to verify the fuel pump is ok.
How old are your basics, plugs/wires/coils?
Related Engine Stall While Driving Content
