1997 Buick Park Avenue Oil in the rad
1997 BUICK PARK AVENUE
235,700 MILES • 6 CYL • FWD • AUTOMATIC
DON IRWIN
Recently I noticed that I have what looks like oil in the filler cap of my rad.
I have just flushed the rad and seen that inside the rad it is coated with the same type of substance,also it is present in the coolant res. tank, however the colant that came out was clean or so I think it is.
I have the cooler infront of the rad and was told this could be leaking.
My car is 1997 buick Park Ave. Ultra 3.8 ltr. S/C with aprox. 236700 km, I have owned it for almost 2yrs and have never had any heat problems or overheating and I change my oil every time the oil life index gets down to 30%.
I have looked at the oil when I change it and I do not see any coolant and the oil filler cap is clean, it also doe's not burn oil more than what I think it should.
Any help or suggestions would be greatly appreceated.
Thanks to all who can help.
Mar 19, 2010 at 9:45 AM
HMAC300
  • 48,601 POSTS
this can be a couple of things. BEst thing to do is get it pressure checked. This could be a head gasket or intake gasket. I'd probaby think the intake gasket as they had problems wth them for a fewt years. It could also be the trans coolant line in the rad broke, but i doubt that. I'd say the previous 2 are the ones worth checking out....
Mar 20, 2010 at 6:39 AM
