Hello, did you try cranking in neutral, maybe a problem with the neutral switch? If you watched the headlites or dash lites with the key in the crank position, and the lites stayed bright, no reaction and no starter action, it doesn't sound like there is any load on the starter system. You still need to be sure the battery has a full charge and the connections are good.
SPONSORED LINKS
Monday, August 24th, 2009 AT 10:28 AM
