I have an 91 Buick Park Avenue. Car will not start I replaced the starter and nothing it will not rotate. Tried to jump the car off still no start.
PLEASE HELP!
THANK YOU
COX
Saturday, December 29th, 2007 AT 8:12 PM
MECHANIC
Is the battery good? If so double check the connections/make sure it clean and tight. Have helper hold key to start and look for battery voltage at the starter small purple wire-do you have it?
