1992 Buick Park Avenue
AHILL1385
  • 1992 BUICK PARK AVENUE
  • 6 CYL
  • FWD
  • 149,000 MILES
My airconditioning stopped cooling. It appears that the compressor is not kicking in when the air is turned on using the auto control. It goes to econ and the air is warm. There are no leaks. I. Ve had it vaccumed and refilled and it does not kick. Could there be a electrical problem? Is there a switch that might be bad. A week ago it came on was cooling but went back to econ. What do you suggest I check.
Thursday, August 21st, 2008 AT 2:36 AM
WILL4785
I had the same problem in my car where it would go to econ instead of auto. All you have to do is disconnect the negative terminal on the battery for 10 seconds then connect it again and it should work.
Saturday, August 23rd, 2008 AT 12:03 AM
