upper intake question
BUICK LESABRE
TWISTED03
im sure youve heard it before my g/f has a 97 lesabre, she was told by the mechanic that she needs to replace the upper intake gasket , after some research weve found that this is a very common problem and replacing the gasket wont fix it because the problems is with the egr valve burning a hole in the intake. my question bsically is if is the replacment part built to with stand this or is there something else i need to do/have done? thx in advance
Mar 8, 2007 at 5:28 AM
CHEVY22
  • 1,375 POSTS
no the new part is an update , just get one from gm , not anywhere else
Mar 8, 2007 at 5:31 AM
TWISTED03
[quote:1720f03f9e="CHEVYII"]no the new part is an update , just get one from gm , not anywhere else[/quote:1720f03f9e]
ok so i will be fine as long as i get the part from gm then.
Mar 8, 2007 at 5:33 AM
CHEVY22
  • 1,375 POSTS
yes indeed , good luck
Mar 8, 2007 at 5:35 AM
TWISTED03
[quote:bcd811d047="CHEVYII"]yes indeed , good luck[/quote:bcd811d047]
thx alot :D
Mar 8, 2007 at 5:39 AM
