burns gas fast
173,085 MILES • 6 CYL • FWD • AUTOMATIC
JEREMY HARVEY
My car is burning gas fast. i just did an oil change and filter. i changed the air filter and i redid the break lines all around. i replaced the fuel line and filter i replaced the water pump and i did a upper and lower intake manifold gasket change and seals with a new thermostat because i needed it done, but it seems to now be going through gas really fast. What can it be or do you think?
Jun 29, 2016 at 11:05 PM
HMAC300
  • 48,601 POSTS
recheck work on intake manifold as it may have a gasket leak. check vacuum at intake and if below 15" at idle it probably is. try spraying choke cleaner at gasket area then scan for codes.
Jun 29, 2016 at 11:15 PM
RENEE L
  • 1,260 POSTS
Hi Jeremy,
Has a tune up been done on your car recently? If not here is a link to a great article from this site that is an easy step by step guide on how to tune up an automotive engine, though each engine configuration is different the process is similar.
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Thank you for visiting 2CarPros If you have further questions please come back to the site as we are always happy to help.
Kindest regards,
Renee
Admin
Jun 30, 2016 at 9:47 AM
