1993 Buick LeSabre Stalls Under Throttle
You need to see if system is running rich or lean. Check proper fuel pressure. Give it a tune-up. As far as your thermostat, replace it. Can you tell if circulation through radiator. Be careful on a hot engine.
Check for applicable trouble codes. Your obd1 so you should be able to check some codes, yourself. To check codes, use a jumper wire at the A & B terminals at the datalink connector. Turn key just till the dash lites come on, no further, then the mil on the dash starts flashing, you count the flashes to get the codes. Your looking for two digit codes.
Suggested Repair
Check whether the engine is running rich or lean and verify proper fuel pressure, then perform a tune-up. Replace the thermostat and confirm coolant circulation through the radiator, being careful on a hot engine. Retrieve OBD-I trouble codes by jumping the data-link A and B terminals and counting the check-engine light flashes.
Conversation Summary
The owner of a 1993 Buick LeSabre with over 100,000 miles says it drives only with very light throttle and stalls if the accelerator is pressed harder. There is also no flow in the hose from the thermostat to the radiator while the engine is running. The expert recommends checking fuel mixture and fuel pressure, doing a tune-up, replacing the thermostat, confirming radiator circulation, and reading OBD-I flash codes.
