1993 Buick LeSabre Dies While Driving
GJTHREET
I have a 1993 Buick Le Sabre with 209,000 actual miles.You can be going along and it just dies and then sometimes it takes 25 to 30 minutes before it will start back and othr times it will start right back. I have been told it was the Crank Shaft Postioning Sensor. My question is. where is it located at , is it hard to change and does it take a special tool to change it.Please help my car done this to me on the interstate doing about 70.
Jun 15, 2006 at 5:24 PM
JDL
  • 16,098 POSTS
Sorry for the late reply.
The crank sensor should be behind the crankshaft pulley. To remove, remove the belt, safely raise and support the vehicle, remove passenger side front tire. There may be an inner fender lining that you have to remove also. You have to remove crank pulley, 28 mm socket for nut removal.
Any time your working under a vehicle there are safety issues, safety is your responsibility.
Mar 17, 2015 at 3:39 AM
Suggested Repair
The crankshaft position sensor is behind the crankshaft pulley. Remove the belt, safely raise and support the vehicle, remove the passenger-side front tire and any inner fender liner, then remove the crank pulley nut with a 28 mm socket.
Conversation Summary
The owner of a 1993 Buick LeSabre with 209,000 miles says the engine dies while driving and sometimes will not restart for 25 to 30 minutes. They were told the crankshaft position sensor may be the cause and asked where it is and whether replacement needs a special tool. The expert says it is behind the crankshaft pulley and outlines access, including belt, tire, fender liner, and a 28 mm socket, with a safety warning.
