1998 Buick LeSabre Radio Volume Rises
444FIRE
  • 21 POSTS
the radio volume raises to full on. my radio has steering wheel controls. the steering wheel volume switch will not raise volume, only decrease, but not when volume is raising in its own. i don't want to repair it, only stop it. where and which wire do i cut? 1998 lesabre limited, 45K miles, 3.8L. thanks.
Aug 25, 2007 at 2:16 AM
2CARPRO JACK
  • 11,533 POSTS
Dont cut any wires. Try removing the steering wheel cover to gain access to the controls and unplug them or see what color wires they are and unplug them at the bottom of the steering column
Aug 26, 2007 at 1:08 AM
FPS_DEAN
I had a 2000. Sometimes if I lower the volume on the steering wheel it would let me raise it.
Just a thought, although you probably tried that.
Aug 30, 2007 at 2:44 PM
Suggested Repair
Do not cut any wires. Remove the steering wheel cover, unplug the steering wheel audio controls, or disconnect their wiring at the bottom of the steering column.
Conversation Summary
The owner of a 1998 Buick LeSabre says the radio volume rises to full by itself. The steering wheel volume control can only lower the volume and does not stop the automatic increase. The owner wants to cut a wire rather than repair it. The expert advises against cutting wires and recommends unplugging the steering wheel controls or their wiring at the bottom of the steering column. Another user mentions that lowering the volume from the steering wheel sometimes restored volume control on a 2000 model.
