1987 Buick LeSabre Stalls in Drive
DOUG605
3.8l vin code 3 new part list module, wires, plugs, coils, injectors x6 car will start and ilde but as soon as you put it in drive it will fall flat on its face compression in cylinder 2 4 6 and1 is 145 cylinder 35 150 fuel pressue koeo is41 lbs koer 25 32 been fighting this for 4 weeks it my only car and i am tired of browing my brother car fuel pump 1 yr old along with sock and filter my email is dtwd@bex.net any help or repose will been greatly apprecated i am not a good speller just what to get may car fixed before i deep six in the river :D
Oct 9, 2007 at 6:56 AM
CLY
  • 308 POSTS
Hey Doug...
Those cars had there own little stall diagnosis book that came out when they were new(lots of problems)...I would like for you to unplug the mass air flow sensor and see what the car does. another part that was known to fail on these cars is the crank sensor but that usually is a hot engine stall and the car wont restart....
Let me know...
Cly
Oct 12, 2007 at 9:16 AM
MLAMUN
[quote:16b6cfb832="Cly"]Hey Doug...
Let me know...
Cly[/quote:16b6cfb832]
Cly,
I have the same problem as Doug with the same year and manufacture, but mine falls under the hot engine stall and after a few minutes the engine will restart only to stall at a later time (Buick Roulette). No stutter just stalls. Any idea would help.
Jan 6, 2008 at 2:53 PM
Suggested Repair
Unplug the mass air flow sensor and test whether the stall in drive stops. If the engine stalls when hot and will not restart, inspect the crankshaft position sensor.
Conversation Summary
A 1987 Buick LeSabre with a 3.8L engine starts and idles but stalls when shifted into drive despite new ignition parts, injectors, fuel pump, sock, and filter. Reported compression and fuel pressure were given. The expert recommended unplugging the mass air flow sensor as a test and noted that the crank sensor commonly causes hot stalls that prevent restarting. A second owner reported a similar hot stall but received no separate diagnosis.
