2001 Buick Lesabre Air Conditioning
175,000 MILES • 6 CYL • FWD • AUTOMATIC
BURBINSKY
When the air is blowing, it doesn't get cold on the driver's side vents. It is very cold on the passenger side. Also I sometimes hear a clicking noise in the dash when the vehicle is started. This clicking sounds almost like a stuck motor. It only lasts for a short time. Could this be related and if so what should I look for to repair?
Jun 29, 2010 at 9:58 AM
  • 75,988 POSTS
Could be an air mix/blend/mode door problem, vacuum and actuator or the HVAC control module. You need to open it up and investigate
Jun 29, 2010 at 10:14 AM
BURBINSKY
Is that accessible from under the hood or does one have to dig into the dash?
Jun 29, 2010 at 10:24 AM
  • 75,988 POSTS
Its behind the dash, make sure you have a book when you decide to do it-
Jun 29, 2010 at 10:26 AM
BURBINSKY
Thanks, I will
Jun 29, 2010 at 10:27 AM
