1998 Buick Lesabre digital climate control unit went blank
100,000 MILES • 6 CYL • FWD • AUTOMATIC
JERAMIAH9999
I have a 1998 Buick Lesabre. The other day the digital climate control unit went blank and heater and ac wouldn't work. Sometimes when i start the car all the possible options will be lit up on display, other times it is just blank. The unit seems to be getting hot. Digital clock above works as does radio. The lights in buttons also work. I'm not sure exactly when this happened, but the day it happened two things happened. First I spilled some juice which was sitting on dash, it appeared to drip down the face of unit. I also got stuck in a ditch, I was able to get out of ditch but i reved the engine quite abit in the process. Thanks in advance for any input.
Mar 1, 2010 at 8:25 AM
CARADIODOC
  • 34,414 POSTS
Don't think wandering through the ditch is part of the problem, juice, maybe, but broken connections are real common. On some modules, simply unplugging them and plugging them back in will appear to solve the problem, . . . for a little while. The scratching action of sliding the connector contacts cleans a spot in the light film of oxidation. There can also be broken solder connections inside on the circuit board. These two things seem to be responsible for half the failures. Various lights flickering on and off, unit going totally dead, and some functions not responding are common complaints.
Hmm. Not responding. I wonder if it was built by Microsoft?
If you pull the module out with the ignition switch turned on, wiggle the connector and flex the unit. If good things happen, (or you see things changing), suspect intermittent connections.
caradiodoc
Mar 1, 2010 at 9:04 AM
BELLA1609
i have a 1998 oldsmobile lss and i have changed the blower motor and blower motor module and the hvac programer and now the climate control is saying -4 and all the lights r on now
Jan 14, 2012 at 5:58 PM
RIVERMIKERAT
  • 6,106 POSTS
bella, have it scanned for codes and let us know what you find out.
Jan 26, 2012 at 4:58 PM
