HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Buick
Lesabre
Climate Control
Heater
Not Working
2000 Buick Lesabre Heater Problem
JOSHLIN1932
MEMBER
2000 BUICK LESABRE
Heater problem
2000 Buick Lesabre 6 cyl Front Wheel Drive 71450 miles
The passenger compartment of my car does not receive any heat. The hoses are hot going to the firewall, but no heat gets into the car. Can you help?
Wednesday, December 19th, 2007 AT 9:29 PM
BMRFIXIT
MECHANIC
Under dash blend door motor
Thursday, December 20th, 2007 AT 5:11 PM
FTEDIOUSLY
MEMBER
Do you figure out you r hater problem I have a similar one. With LeSabre 94.
Saturday, December 29th, 2007 AT 3:25 PM
BMRFIXIT
MECHANIC
What is your problem
yours may be diff
try flushing the heater core
let me know
Saturday, December 29th, 2007 AT 7:54 PM
Please
login
or
register
to post a reply.
Related Heater Not Working Content
Nothing Comming From Driver Side Vents, Passenger Side...
I Have Nothing Comming From Driver Side Vents, Passenger Side Has No Heat (dont Know Bout A/c Its 35 Degrees Out), It Will Not Switch To...
Asked by
speedalot35951
2000
BUICK LESABRE
VIDEO
Heater Not Working
Instructional repair video
GUIDE
Heater Not Working
Step 1 - A heater cannot operate unless the engine is full of coolant/antifreeze. If coolant level is low check the system for leaks.
Heater On High Is Only Luke Warm. Gauge Reads 192....
Heater On High Is Only Luke Warm. Gauge Reads 192. Both Hoses Going Into The Firewall Are Hot. Air Works Fine But The Heater Doesnt Put Out...
Asked by
Anonymous
2000
BUICK LESABRE
Heater Blowing Cold Air
I Have A 2000 Buic Lasaber And My Heater Is Blowing Cold Air I Changed The Thermistat And The Water Pup Wha Could It Be Now Because It Still...
Asked by
tabatha186
1 ANSWER
2000
BUICK LESABRE
Heater Blows Cold Air. Where Is The Temp Actuator...
Heater Blows Cold Air. Where Is The Temp Actuator Located?
Asked by
Anonymous
1 ANSWER
2000
BUICK LESABRE
I Am Not Getting Heat Coming Out Of The Vents
When I Set Automatic On My Heather/air Conditioner Control I Am Not Getting Heat Coming Out Of The Vents. There Was A Noise Being Made In...
Asked by
afliegel
4 IMAGES
2005
BUICK LESABRE
VIEW MORE
Heater Not Working
Blend Door Actuator Replacement
