2000 Buick Lesabre brakes won't build pressure
2000 BUICK LESABRE
173,000 MILES • 6 CYL • FWD • AUTOMATIC
JJZEV85
Hello. I just replaced my rear brake line and rear calipers. I bled the system and it built up proper pressure, but when I turn the engine on it losses pressure. Just going up and down the driveway the car seems to stop OK but it still take a lot of work, as if the lines were not bled.
As a note, when removing the rear lines, I was attempting to heat a coupling with a torch and did accidentally catch some of the insulation on the firewall on fire. I put it out quickly. Upon inspecting the area it appeared the only damage was to a wire that I believe is for the ABS system. While I will get that replaced I don't see why it should adversely affect the normal performance of the brakes.
Is it possible the fire damaged something the brakes need to operate? I have bled the system from the rear before and have never had this issue.
Sep 7, 2010 at 1:31 PM
WRENCHTECH
  • 20,761 POSTS
Go back and look at the calipers and tell me if the brake bleeders are on the top or the bottom of the calipers.
Sep 7, 2010 at 1:38 PM
JJZEV85
They are at the top of the calipers.
Sep 7, 2010 at 2:13 PM
WRENCHTECH
  • 20,761 POSTS
That tells us the calipers are on the correct side of the car. It sounds like you just still have air in the system. You will likely need a pressure bleeder to get it bled properly. You may even have to electronically bleed it internally with a scan tool.
Sep 7, 2010 at 2:16 PM
