1999 Buick Lesabre Hard Start/Stalls
TKERR1
Engine Performance problem
1999 Buick Lesabre 6 cyl
Car turnsover but has a hard time starting. Sounds like it has trouble getting gas to the engine. Eventually, 8 seconds or so, it will fire sluggishly and start. Idles rough for 10 seconds, then runs fine. I noticed that when it is idling rough the voltmeter on the dash is struggling (10Volts or so) to get to the normal position. Then when it runs fine the voltage goes up to normal. It also stalls when idling at a traffic light. I notice that the volt meter goes back to the 10Volt range before it stalls. Mass Airflow Sensor was recntly replaced. No check engine lights have come on. Any Ideas?
Aug 30, 2008 at 7:41 AM
JDL
  • 16,098 POSTS
Just do some of the basic tests. Check fuel pressure, check for codes.
Some of the national brand autostores will check codes for free, they might also loan-out a fuel pressure gage.
On a fuel injected vehicle, a fuel pressure gage is a basic tool, you need one. Even if it turns out, fuel pressure isn't your problem, this time.
If it dies at closed throttle, check the idle-air system. Give the throttle-body a good cleaning, check the iac valve and passages.
Aug 31, 2008 at 7:00 AM
