1999 Buick Lesabre coolant got dark fast
1999 BUICK LESABRE
77,000 MILES • 6 CYL • FWD • AUTOMATIC
BUICK9874
coolant was pink so I guess it was Dexcool. Over two weeks it gradually became dark red and looked like it had dark dirty oil in it. Smelled like oil I thought. I think my mechanic topped the overflow with a little bit(maybe half cup) of antifreeze that was not pink. But we did pour in a small bottle of leak stop into the antifreeze. There was a very slow coolant leak. I think he said the intake manifold gasket was on its way out. That would leak antifreeze, right? Also, would the clear -leak stop liquid react with Dexcool to turn it black/dark red and make the temperature shoot up from 150 to 175 to almost 200? I had a flush done and the temp seems to be holding btw 150-160.
Dec 10, 2008 at 3:45 PM
  • 110,244 POSTS
Hi:
It is possible for oil to enter the coolant if there is a headgasket or intake problem. Make sure there is no coolant getting into the oil. As far as the dexcool, the stop leak he used may have caused it to get dark. However, I wouldn't expect it to get really dark. Finally, the normal operating temp for your engine is right around 195 to 205. The thermostat shouldn't completely open until 195. But did the change just start since he added the stop leak? Do you know what brand of stop leak was used?
Dec 16, 2008 at 1:20 PM
