1998 Buick Lesabre prime engine oil system
1998 BUICK LESABRE
97,000 MILES • 6 CYL • FWD • AUTOMATIC
JSPEHAR
Hi the car has been sitting about a year
have replaced water pump and belt
i need to prime the oil pump or system
so i can start the engine. how do i
prime the system. thanks john
P.S. i shoud add that the oil pump is
in the front in back of the balancer.
engine is 3.8L 6 cyl.
Sep 16, 2010 at 3:11 PM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
you can pull the distriutor out and put a driver that fits the oil pump drive and not hit the cam gear and usea a large drill to turn the pump over. or disconect the coil or coil wires and crank the engine to prime it. it should be ok to do that......then start it up.
Sep 16, 2010 at 6:19 PM
JSPEHAR
thanks for your input! but that ok for my
old 350 or any engine that has a dist.
this oil pump is driven by the crankshaft.
thanks again john
Sep 17, 2010 at 12:39 AM
HMAC300
  • 48,601 POSTS
then disconnect the coil pack so the car won't start and just crank the engine over you still have residual oil in thebearings so they won't be dry....
Sep 17, 2010 at 1:52 PM
