1998 Buick Lesabre maintenance
1998 BUICK LESABRE
PUG1975
1998 Buick Lesabre
I need to know does my car have shock or struts and when should i have them replaced. I'm asking because know i'm bouncing up and down more than before when driving.
Jan 22, 2010 at 4:49 AM
MMPRINCE4000
  • 8,548 POSTS
Struts.
Look at strut cartridge from under car, if you see hydraulic fluid on piston, strut cartridge will have to be replaced.
Cartridge is strut without spring, generally you reuse the old spring, remove with a spring compressor.
You can also buy "quick struts" which include a new spring and are bolt on. The disadvantage is that they are $200 each or so, as compared to $60 or so for cartridge.
Jan 23, 2010 at 1:06 AM
