2005 Buick Lesabre rear air shocks
CWMITCHELL
  • 2005 BUICK LESABRE
  • 6 CYL
  • FWD
  • 60,000 MILES
I replaced the original air shocks with after market air shocks and the car rides very stiff. I put 400 lgs of weight in the trunk and the compressor didn't seem to raise it at all. The compressor worked fine with the old shocks. Can I disconect the air and use them as regular shocks
Sunday, November 29th, 2009 AT 1:44 AM
DENNYP
  • 1,824 POSTS
They will not function as regular type shocks. Check your air lines for leaks by spraying them with soapy water when the compressor is running. You should also spray the air bladders on the shocks to check for leaks.
Monday, November 30th, 2009 AT 9:22 PM
