1997 Buick LeSabre Seat and Window Issues
TW123
I have a 1997 Buick LeSabre 3.8, aprox 140kms.
I have 2 questions;
1. The power seats are not functioning. When I removed the fusebox cover the larger silver 'breaker fuse ?' was and still is, too hot to touch. What is the problem? Is it as simple as a new fuse??
2. The power window on the passenger side stopped working. It would work intermitantly before but now seems to only work very occasionally. When it does work, the master control on the drivers side (for passenger window), also works. DO I have to replace the entire passenger window button assembly?
Please help.
Thanks,
Tony
Jan 22, 2007 at 7:16 AM
CARUNDELL
  • 602 POSTS
[quote:f53e82094d="TW123"]I have a 1997 Buick LeSabre 3.8, aprox 140kms.
I have 2 questions;
Please help.
Thanks,
Tony[/quote:f53e82094d]
Hey Tony,
The hot breaker indicates that its "tripping". something is causing an excess load on the circuit. Either the seat is jammed/frozen or the elec. motor or linkage for the seat has failed.
A common problem with the widow operation is the wiring harness between the door jam and the door is in a rubber boot and over time the wires in that boot break. I would check that first before trying to replace any switches! Let us know!
Chris
Jan 22, 2007 at 7:58 AM
Suggested Repair
Do not just replace the hot seat circuit breaker. A breaker that is too hot to touch is tripping from excess load, so check for a jammed or frozen seat or a failed seat motor or linkage. For the intermittent passenger window, inspect the wiring harness in the rubber boot between the door jamb and door for broken wires before replacing the window switch assembly.
Conversation Summary
The owner of a 1997 Buick LeSabre reported inoperative power seats and a circuit breaker that was too hot to touch, plus a passenger window that worked only occasionally. The expert said the hot breaker indicates excess load from a jammed seat or failed motor or linkage, and advised checking the door-jamb wiring harness before replacing window switches.
