Auto window (driver's side is stuck down) but can hear motor when push switch
167,000 MILES • FWD • AUTOMATIC
KENTLY51
Yes, I can hear the motor trying to work for my driver's side window but the window is stuck in the down position and it's all the way down. Not sure I should experiment with removing panel and all without a new regulator? Is it possible the window is misaligned and simply not in the proper position to be lifted "up" since I can hear the motor working? I have no testing equipment to isolate where the link is and was hoping if I removed panel, the window would simply need to be put back into position and function with motor I can hear. I've watched numerous You Tube videos but I don't seem to see anyone discussing options if you CAN hear the motor working.
Nov 14, 2015 at 3:53 AM
if the motor is working then the regulator has failed. there is no putting the window back on track as this does not happen with the newer cars.
Here is a guide to show you what you are i for when doing the job.
https://www.2carpros.com/articles/how-to-check-and-replace-a-electric-power-window-motor
you can get the regulator on Amazon.
If the regulator is okay there is a DDM driver door module inside the door which gets wet and goes out. This can cause the issue as well.
Nov 14, 2015 at 11:08 PM
