1997 Buick Lesabre electronic spark control module
1997 BUICK LESABRE
45,000 MILES • 6 CYL • FWD • AUTOMATIC
KATRINAS1
my was sputtering and making all kinds of noises and my check engine light came on. I pulled over and shut it off. It will not turn on. my battery, alternator, fuel pump are all good. someone suggeted it could be electronic spark control module? what is it, how is it tested,
Nov 1, 2008 at 7:23 PM
DENNYP
  • 1,824 POSTS
You can take it off the car and take it to Autozone or someplace like that. They can test it for you for no charge.
Nov 3, 2008 at 8:46 PM
KATRINAS1
electronic spark conrol module tested good. So I towed the car home. I guess next I will try starter for testing. If that is not it I have no idea what it could be. any ideas?
Nov 4, 2008 at 6:18 AM
DENNYP
  • 1,824 POSTS
Does the engine crank when you turn the key?
Nov 4, 2008 at 12:58 PM
KATRINAS1
no the engine just clicks.
Nov 4, 2008 at 2:02 PM
DENNYP
  • 1,824 POSTS
Make sure you don't have engine coolant in the oil. If it quit while driving and then the starter wouldn't crank the engine, it could be hydrolocked with coolant. Try to rotate the crankshaft a couple of revolutions with a breaker bar or ratchet.
Nov 4, 2008 at 5:53 PM
