1996 Lesabre Engine misfires, hesitates up hills Stalls once
DINOMAN22
  • 1996 BUICK LESABRE
P0102 Mass or Volume Air Flow Circuit Low Input
P1654 Cruise Disable Output Circuit
Took it in to PEPboys they wanted $953?
Getting second opinion!
To my knowledge car hasn't had a tune up in a long time
Should a tune up fix this issue? Already out $90 for the diagnosis.
Tuesday, September 11th, 2007 AT 11:32 AM
ZUE
  • 76 POSTS
A MAF device from your local auto store is only about 90.00 and not so had to replace. If you are recieving a P0102 then you do have an air flow issue. First try checking to see if you have a vacuum leak. Get a can of Starter Fluid and spray it around your vacuum hoses and base of manifold. If there is a substantial leak the RPMs will increase for a moment. Fix leaky hoses first as this is cheaper.
Have you used an oil based airfilter like K&N. If so over-oiling can cause contamination of the MAF. Use an electroinic cleaner (Radio Shack) to spray on MAF device to clean it. This is also a cheap maintance test.
A tune-up is always necessary if you have waited a long time.
Friday, September 21st, 2007 AT 11:44 PM
