1995 buick lesabre
1995 BUICK LESABRE
KEVINTX1
1995 buick lesabre, v6 ,3800, 88,000 miles when vehicle is warm it stalls then starts right back up with out any hesitation , have replaced ign module , coils fuel pump , crank sensor and cam sensor, its not setting any codes any help please thanks
Oct 30, 2007 at 8:09 AM
BMRFIXIT
  • 19,053 POSTS
[quote:30ebdd49fa="kevintx1"]1995 buick lesabre, v6 ,3800, 88,000 miles when vehicle is warm it stalls then starts right back up with out any hesitation , have replaced ign module , coils fuel pump , crank sensor and cam sensor, its not setting any codes any help please thanks[/quote:30ebdd49fa]
did u check the idle air cont.
or it may be a prom problem need update
good luck
Oct 30, 2007 at 12:34 PM
TCCC143
  • 21 POSTS
Check the fuel pressure regulator. It tends to fail after vehicle reaches temperature. If not that have someone check the fuel pressure once the vehicle shuts down. Could be related to a poor fuel pump or clogged filter.
Nov 8, 2007 at 11:06 AM
