1994 Buick Le Sabre Interior Lights Blink
DEMONSIN
recently purchased a used 1994 buick le sabre. whenever a door is closed the interior lights blink for a good 30-60 seconds. this also happens when i turn the interior lights on then off with the panel lights dimmer switch. they don't blink while they are supposed to be on... ie when the switch is on....or a door is opened... only when they should be off. I checked fuses and they are all good. any clue why this would be happening?
Mar 17, 2007 at 1:24 AM
ANIL111
I have a 1995 and have similar problems, for a year or so. Sometimes autolocks do not work and at the same time inside lights do not come on at all. Once in a while they will work for one day or less and will not work most of the time.
Sometimes inside olights will stay on when car is shut. I carry a wrench to remove battery negative terminal under my car seat for quick access.
Recently I have brake light and bell problems. They do not turn off.
good luck and if u find any solution please let me know. Thanks. anil9999@walla.com
Mar 31, 2007 at 1:12 PM
