1996 Buick Lesabre headlights and interior lights not worki
1996 BUICK LESABRE
DCPETTWAY
Electrical problem
1996 Buick Lesabre 6 cyl Front Wheel Drive Automatic
My car's headlights and interior lights did not work when I left for work this morning, could that be a fuse problem, or possibly something else.
Sep 21, 2009 at 12:45 AM
JDL
  • 16,098 POSTS
I'd get at the connector, lower steering column. You may have to remove lower part of dash. With the headlites turned on, lite blue wire carries voltage to the dimmer switch.
There is a headlamp circuit breaker, underhood fuse box. Use a testlite, the circuit the breaker plugs into should have voltage all the time.
Sep 21, 2009 at 2:05 AM
