my brake pedel goes to the floor on the first pump, but stays up on the second pump. I replaced the master cyllinder, no help, all the pads, shoes, rotors &drums look like new
Tuesday, August 18th, 2009 AT 7:06 PM
BLUELIGHTNIN6
MECHANIC
Check vacuum lines at brake booster and make sure brake fluid is topped off
SPONSORED LINKS
Tuesday, August 18th, 2009 AT 11:45 PM
HARVY DAVIDSON
MEMBER
All that is good. But when we bleed the brakes, one side keeps having air. It is not leaking fluid, but seems to pull in air.
