1978 Buick LeSabre Fuel Pump Replacement Fix
DEWBERDOO
i need general help with removal and replacement of the fuel pump. any tips would be much appreciated.
1978 buick lesabre
350 cu.in. 4 barrel
Sep 19, 2007 at 2:01 PM
BUDDYCRAIGG
  • 2,262 POSTS
fuel pump is on the side of the engine, towards the front.
GM was just starting to put different engines in different cars in the mid 70s. So you could have a Chevy 350 in your buick.
If your distributor is on the front of your engine then you have a buick. if it's in the back it could be Olds, Pontiac or Chevy.
changing the pump is pretty straight forwards.
remove lines and hoses.
remove bolts.
remove pump
and put it all back together.
on some engines, like a Chevy, there will be a shaft that keeps sliding down in your way when trying to put the pump lever back in.
good luckk
Dec 12, 2008 at 12:54 PM
Suggested Repair
The mechanical fuel pump is on the front side of the engine. Disconnect the fuel lines and hoses, remove the mounting bolts, and replace the pump. Confirm the engine family by distributor location, and on Chevy-style engines watch for the pump pushrod dropping while installing the lever.
Conversation Summary
The owner of a 1978 Buick LeSabre with a 350 and four-barrel carburetor asked for general fuel pump removal and replacement tips. The expert said the pump is on the front side of the engine and that the car may have a Buick or another GM 350 depending on distributor location. Replacement involves removing the lines, hoses, and bolts, then reinstalling the pump, with caution about a shaft that can slide down on some engines.
