HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Buick
Lesabre
Fuel System
Fuel Pump
Replace/Remove
Locating and changing fuel pump
MAC5951
MEMBER
1988 BUICK LESABRE
6 CYL
FWD
AUTOMATIC
10,000 MILES
Do I have to drop the gas tank to get to the fuel pump, had the back seat out and dint find it under there?
Tuesday, March 23rd, 2010 AT 9:21 PM
BLUELIGHTNIN6
MECHANIC
Yes, there is no access panel to the fuel pump. the tank must be drained and lowered to replace the fuel pump.
Here is guide to help you step by step on a similar car the procedure is the same.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
SPONSORED LINKS
Tuesday, March 23rd, 2010 AT 9:40 PM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Replace/Remove Content
1990 Buick Lesabre Fuel Pump Replacement
How To Replace The Fuel Pump On A 1990 Buick Lesabre. Also, There Are Two Pumps For This Car.1.45" Diameter And 2".
Asked by
Roadbird383
1 ANSWER
1990
BUICK LESABRE
GUIDE
When a fuel pump goes out it can do so one of two ways either it can quit and stop working or it can fail intermittently causing the engine to stall or not start.
1978 Buick Lesabre Fuel Pump Replacement Help
I Need General Help With Removal And Replacement Of The Fuel Pump. Any Tips Would Be Much Appreciated. 1978 Buick Lesabre 350 Cu. In. 4...
Asked by
dewberdoo
1 ANSWER
1978
BUICK LESABRE
Fuel Pump? Or Something Else
1995 Buick Lesaber Ok So I Put Some Gum Out In It With The Last Oil Change And It Started Sputtering Periodicly So I Changed The Fuel Filter...
Asked by
tcooperson
1995
BUICK LESABRE
Fuel Pump How Do You Replace?
How Do You Replace A Fuel Pump On A 1997 Buick Lesabre
Asked by
david morrissey
3 IMAGES
1997
BUICK LESABRE
1998 Buick Lesabre Should I Get A Diagnostic
For The Last Month My Car Has Been At A Garage. The Fuel Pump Went And He Replaced It. The Next Day I Tried To Go To Pick It Up And It...
Asked by
sherry-robinson
1 ANSWER
1998
BUICK LESABRE
VIEW MORE
SPONSORED LINKS
How to fix an engine that wont start
Engine Not Starting
Fuel Pump Pressure Test
Online car repair manuals
