Thanks
edglr@netscape.net
Confirm whether the noise is normal fuel-injector ticking. If it is valvetrain noise, have the hydraulic lifters checked or replaced, since springs and valves were already replaced. Brief tapping after startup can occur while oil pumps back up after draining into the pan.
The owner of a 2001 Buick Century reports persistent tappet-like noise despite two spring and valve replacements and four oil changes. Another owner describes similar noise for the first minute or two after startup. An expert says the sound on newer vehicles is often normal fuel-injector noise and asks whether the lifters were replaced. The expert also explains that oil drains into the pan while parked, so brief tapping can occur until oil pressure is restored.
