1992 Buick Century Front Windows Dead
FATHERTIME271
I have a 1992 Buick Century, 3.3ltr engiine, it has 234,000 miles on it. The front power windows will not operate, the back windows operate fine. I have changed the driver's side master switch panal, both power window motors, and the fuse checks good. Both windows are getting voltage. But neither front window will operate. Is there something that I'm missing, and where is it located?
Mar 25, 2007 at 3:20 AM
2CARPRO JACK
  • 11,533 POSTS
Check all the grounds and be sure the wiring is good where it passes from door to body of the car
Mar 26, 2007 at 12:36 AM
MDPATS
  • 19 POSTS
I've actually have had the exact same problem as described here. I was experimenting today and realized that when the door was all the way open, the switches worked fine and the passenger and driver side windows went up and down fine. However, when I closed the door just a small bit, the front windows would stop working all together. I removed the boot between the door and the car which revealed the rest of the wiring harness. I found three wires that have been broken off which was causing the failure.
Apr 12, 2007 at 2:06 PM
Suggested Repair
Inspect the wiring harness where it passes through the boot between the front door and the body. Repair any broken wires and confirm the grounds and harness connections are sound.
Conversation Summary
A 1992 Buick Century had inoperative front power windows while the rear windows worked. The master switch, both front motors, and the fuse had already been checked, and voltage was present. An expert advised checking grounds and the wiring where it passes from the door to the body. Another owner with the same symptom found the windows worked only with the door fully open; three broken wires in the door-to-body harness were causing the failure.
