How do you change the ignition in a 1998 buick century. How do you release the one on the column. Thanks Jaime
Nov 14, 2007 at 10:35 AM
Turn the key to the on position. Insert a straightened paper clip into the release hole on the column beside the ignition cylinder, push the button in, and pull the ignition cylinder out at the same time.
The owner asked how to release and change the ignition cylinder on a 1998 Buick Century. The expert said to turn the key to on, insert a straightened paper clip into the hole by the cylinder, push the release button, and pull the cylinder out at the same time.
