1994 Buick Century A/C Vacuum Leak
BUICK94OWNER
I own a 94 Buick Century and the problem just popped today. I was out doing my daily rounds and had the A/C running, it worked fine up until I headed to Wal-mart. Before entering, it worked but when I left the store, it was no longer running. I can hear the hiss of air escaping when I try to turn the system off and on, but it sounds like the fan isn't running. What's wrong and can it be severe? A reply ASAP would be greatly appreciated.
Apr 13, 2007 at 10:58 AM
MERLIN2021
  • 17,250 POSTS
It does not want you shopping at Walmart...Chinese products harm our jobs!
The air is likely a vacuum leak, Track it down and you may solve the problem. The controls wont operate till the leak is fixed! If it's a vac leak the only a/c position you will have is defrost!
Apr 17, 2007 at 3:52 AM
Suggested Repair
Inspect the HVAC vacuum system for a leak and repair it. A vacuum leak can keep the mode controls from operating and may leave only defrost available until the leak is fixed.
Conversation Summary
The owner of a 1994 Buick Century said the A/C worked earlier, then stopped after a store stop. Cycling the system produced a hiss of escaping air, and the fan did not seem to run. The expert attributed the problem to a vacuum leak and advised tracking it down, noting that the controls will not operate until the leak is repaired and that only defrost may work.
