2001 Buick Century Gas Smell
FORTYAND
we took our car 2001 buick centry with 80,000 miles to the repair shop, but they are not sure what is going on with it. It has a strong gas smell all the time, even if you leave it sit all weekend and then pull it into the garage, we had to pull it back out of the garage because it had our whole house smelling like gas. there is NOTHING what so ever leaking from the car anywhere.
Need you help kindly,
n. :?
Dec 6, 2006 at 1:28 AM
MATHIASO
  • 1,209 POSTS
Have the evaporative emission-control system check for leak, check canister filter if it clogged.
check the vapor delivery line / (canister purge line) from the canister to the fuel distributor.
* An evaporative emission-control system actually functions as both fuel-tank venting system and emission-control system.
Dec 6, 2006 at 2:41 AM
Suggested Repair
Have the evaporative emission-control system checked for a leak. Inspect the canister filter for clogging and check the vapor delivery or canister purge line from the canister to the fuel distributor.
Conversation Summary
The owner of a 2001 Buick Century with 80,000 miles reports a strong gasoline smell even after the car sits all weekend, with no visible leaks. A shop has not identified the cause. The expert recommends checking the evaporative emission-control system for leaks, inspecting the canister filter for clogging, and checking the vapor delivery or canister purge line from the canister to the fuel distributor.
