2000 Buick Century Computer Reset - After Transmission Over
2000 BUICK CENTURY
ELDERBE
Transmission problem
2000 Buick Century Front Wheel Drive Automatic 57000 miles
I was having troubles with my transmission going into a hard shift after it warmed up - I took it to a car repair and the transmission was overhauled (under warranty still thank goodness) - however, after the car was returned I continue to get three lights coming on now and then (not continuous) service engine light, anti-lock, and trac off lights - I took it back but lights were not on at that time and they could not replicate issue - I heard from someone else they had a similar issue after a transmission overhaul and after many times of returning the car they ended up resetting the "computer" and then they no longer had issues - I asked my repair if they had done this but didn't get a straight answer - my question is...does the "computer" have to be reset after a transmission has been overhauled...thanks.
Feb 8, 2008 at 5:28 PM
MASTERTECHTIM
  • CAR REPAIR CONTRIBUTOR
  • 4,750 POSTS
no the computer does not need to be reset. you quite possibly have a different problem or one that was inadvertantly caused when the transmission was rebuilt. the computer should have stored a code. how long after the lights went off did you return for service? how long were the lights on for?
Feb 8, 2008 at 5:44 PM
ELDERBE
the three lights come on at various times and stay on until I turn the car off - sometimes they come on when I leave for work and stay on until the car is turned off but if I start the car up again they don't come on and it is not a daily thing - one day they come on the next day they don't
Feb 9, 2008 at 9:24 AM
MASTERTECHTIM
  • 4,750 POSTS
the codes should still be stored in memory, take back to the shop that did the transmission and have them recheck it again, be a pain in the neck if you have to.
Feb 9, 2008 at 2:40 PM
ELDERBE
Thank you -This was my first time at posting and was very surprised at quick response and was very helpful...thanks.
Feb 9, 2008 at 4:54 PM
