2001 Buick Century evac problem
80,000 MILES • 6 CYL • FWD • AUTOMATIC
BULLDOG217
2001 Buick Cent. V6. check engine light on. Had checked-problem with evac purge valve. Replaced one on top of motor(still on). Had checked again, advised purge valve under left rear fender, replaced(still on). Had a smoke test for leaks done, new valve under fender leaking, replaced again (light still on). Had computer reset, computer shows no problem, light off. Four days later light back on again.???
Jan 24, 2010 at 4:09 AM
SCOTTY DEE
  • 592 POSTS
What is the code that was set?
Jan 28, 2010 at 2:59 PM
BULLDOG217
code was 0441
Feb 14, 2010 at 1:54 AM
SCOTTY DEE
  • 592 POSTS
Are you sure ? Each code is preceded by an alpha letter. (B,P,C,U) i.e PO441. The only code for that model ending in 0441 is a body or B0441. If that is the correct code, B0441, that's an HVAC issue.
Feb 14, 2010 at 3:36 AM
BULLDOG217
I just had scaned again, code is P0446
Jul 19, 2010 at 7:32 AM
