1999 Buick Century wont start
TACKMAN
  • 1999 BUICK CENTURY
Engine problem
1999 Buick Century V6 Two Wheel Drive Automatic 135000 miles
the car was running fine I have not had any problems with this car drove it to work and it will not start back it will turn over but thats all the car is getting about 42 to 48 on fuel pressure there is no fire at coil packs I was told it was crankshaft position sensor I changed it but had know luck need help
Saturday, December 8th, 2007 AT 3:08 PM
BLACKOP555
  • 10,371 POSTS
Try putting a postive 12v to the positive prong on the coil.
You may have bad coil packs, check for voltage at them, if you have power but no spark then you should replace them
Saturday, December 8th, 2007 AT 6:10 PM
TACKMAN
Checked ignition control module and coil packs they where fine wound up being camshaft positioning sensor
Tuesday, December 11th, 2007 AT 6:32 PM
