1999 Buick Century Coil pack
TOBY65
  • 1999 BUICK CENTURY
  • 6 CYL
  • 75,000 MILES
I confirmed coil pack for #3 and #6 needs to be replaced. Can you tell me how to do it myself if possible it seems to look pretty easy. But want to make sure I do it right.
Friday, February 26th, 2010 AT 7:47 PM
JALOPYPAPA
  • 467 POSTS
If you still need a suggestion: If it's like my 1992 3300 V-6, it's about as complicated as plugging in a lamp cord. You use a 7/32 or 5.5 mm socket to remove the two bolts and lift it off two spade connectors. New one plugs in. Should come with new little rubber seal for the connectors. Simple as that.
Monday, April 12th, 2010 AT 7:49 AM
