Air conditioning
LUCYS2GIRL
  • 2002 BUICK CENTURY
  • 97,800 MILES
I had the recharge of the a/c and the refill of the Freon done but the air flow from the vents is warm. The air still blows warm even after 20-30 minutes. Could it be the compressor? If so, how much does that repair run?
Tuesday, July 23rd, 2013 AT 1:34 PM
  • 110,029 POSTS
Is the clutch on the compressor engaging? For it to be recharged, it had to be working. Check it to confirm. Lets look at this guide to help fix the problem.
it sounds like the compressor is not working
https://www.2carpros.com/articles/replace-air-conditioner-compressor
Tuesday, July 23rd, 2013 AT 4:33 PM
MSGTORAM
Thanks for this post I had this problem had to get a new compressor for $212.00 all fixed!
Monday, July 29th, 2019 AT 12:34 PM
SANTRESAMAIRE
  • 1999 BUICK CENTURY
  • 6 CYL
  • 4WD
  • 82,000 MILES
My air conditioner is no longer working. When I turn the knob, nothing happens. It does not make any noises nor does it blow any air at all. Can you provide insight as to what the problem could be and how much it could cost to repair it?
Thanks in Advance
Monday, July 29th, 2019 AT 12:35 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
That would be tough to do. I suggest you go to a shop for an estimate. The system is complex and needs to be seen by a professional.
KWMEMPHIS
  • 6 CYL
  • FWD
  • 117,000 MILES
Hello guys, I have a 99 Buick Century that has a very intermittent AC problem on norm or max settings. At idle the system cools for about 15 mins or so then the compressor cuts out for 1 -10 minutes with a quick cycle several times then resumes cooling. I also noticed this during regular city driving but could not tell if the quick cycling was happening. I attempted to charge the system with 1/2 can of 134 with leak detector but have not found any leaks. Any ideas are welcome before I visit the dealer.
Thank you!
2CARPRO JACK
  • 11,533 POSTS
If you can get it to cycle while idling, use a test light at the cycling switch (on the receive/drier, low side of the system) The switch should have power through it when a/c is working properly, when it begins to cycle, se if the feed side of the circuit is turning off or if the cycling switch is not making the through connection. This will tell you if it is losing signal frrom the dash end or if the cycling switch is going bad and cant handle the load for an extended length of time
JIMMY1985
  • 2000 BUICK CENTURY
  • 6 CYL
My car blows heat and then blows cold air what could it be
Monday, July 29th, 2019 AT 12:36 PM (Merged)
Check the thermostat, coolant level and heater core-if all okay- check the air blend door/actuator operation
AHOWGSLASH
  • 4 CYL
  • FWD
  • 130,000 MILES
The driver side of my A/C is blowing warm air while the passenger side is blowing cold air.
  • 110,029 POSTS
There is a blend door for each side that determines how hot or cold the temp is. If it is warm and you have it set for AC, the blend air door must be sticking.
MYMARLA1
  • BUICK CENTURY
I have a 2000 buick century with 24,000 miles, I have dual comfor temp climate control. With settings down to the coldest settings the drivers side vents are blowing luke warm air and the passenger side vents are blowing ice cold air.
MOJO
I have a 1998 Buick Regal and am having the same problem. Have you been able to solve the problem?
LUIS050
  • 5 POSTS
Its going to be the actual Ajdusting controler I had the same problem but with the pasenger side on a 91 regal. Sins its has the passenger controler separet I could just replace it but if its the driver side youll probably have change the whole module and thats expensive!
BATESDS
Air Conditioning problem
2000 Buick Century Automatic
why does my air only work on high
DOCFIXIT
  • 18,828 POSTS
Most likely a faulty blower resistor
TOOOMANYTOYS
  • 513 POSTS
The blower has a resisitor pack that regualtes the fan soeed. Check the blower resisitor fo signs of a burnt connection.
MAYA CORGI
  • 2001 BUICK CENTURY
2001 Buick Century
How much should it cost to repair the air conditioning on a 2001 Buick Century? It does not work at all. Fan blows and heat works okay.
ZACKMAN
  • 4,202 POSTS
Not knowing what is wrong, I put everything that they may charge you. Add an additional 1 hour if your system leaks.
https://www.2carpros.com/forum/automotive_pictures/55316_01centuryac_1.jpg
KOGLE
2000 Buick Century 6 cyl Front Wheel Drive Automatic
where is the drivers temperature door
2CP-ARCHIVES
  • 4,540 POSTS
  • 150,000 MILES
My heat blows cold while it idles, but gives hot heat when driving.
Related Air Conditioner Not Working Content
