1994 Buick Century Car dies after 20 minutes then starts ag
JD.DUGGER
  • 1994 BUICK CENTURY
  • 4 CYL
  • FWD
  • 89,600 MILES
My car drives for about twenty minutes straight then dies on me. If I let it sit for about twenty minutes it will start right back up and drive for another twenty minutes before it dies again. What is the problem with this car. I was told the fuel filter so I replaced it and it still dies on me. Any information that you could provide would be greatly appreciated. Thank you for your time. I was also told it could be the cold start sensor.
Monday, February 22nd, 2010 AT 7:28 PM
Next time this happens don't wait for nothing, do below immediately to determine whether it's fuel or spark related problem.
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Monday, February 22nd, 2010 AT 8:36 PM
