1994 Buick Century Buick stalls
BIGBOII_01
  • 1994 BUICK CENTURY
  • 6 CYL
  • FWD
  • 142,300 MILES
I have a buick century station wagon and its been dieing like it wasnt getin any gas but would start right back up. Now it died and wont start back up. I checked the fuel pump it holds pressure checked ignition madule it works. And put new fuel filter on
Sunday, June 1st, 2008 AT 3:47 PM
JDL
  • 16,098 POSTS
Do you have spark at the plugs with the engine cranking? Are there any codes?
If there is an oil pressure switch in the fuel pump circuit, once you crank it enough to build oil pressure, the switch closes and the fuel pump runs, so you have pressure, but, if the pcm isn't pulsing the injectors for some reason, there won't be any gas in the cylinders.
My first thought was maybe an intermittent signal from the crank or cam sensor? I'm not saying replace anything, you could do some testing.
Monday, June 2nd, 2008 AT 4:47 PM
